loose map sensor
loose map sensor
is it normal for a MAP sensor to be loose sitting in the intake manifold and it is a 3 pin or 2 pin connector that goes to it?
Re: loose map sensor
Mine sure is. It just has that one clip holding it in. As long as the piece protruding from the bottom (with the orange rubber seal) is in the intake with no leaks, then you are fine.
