H, X, Y pipes....
Old 01-01-2009, 06:18 PM
WS7_FORMULA's Avatar
Question H, X, Y pipes....
Whats so special bout having different shaped pipes???
Old 01-01-2009, 07:33 PM
jrob56's Avatar
is this a serious question or a joke?
Old 01-01-2009, 07:38 PM
steveo346's Avatar
hahaha...naw i think roy is being serious
Old 01-01-2009, 07:46 PM
98RedBird's Avatar
Search, Search, Search... has been beaten to death.
Old 01-02-2009, 01:18 AM
hey hey hey, Im new here. But fine dont help me....
Old 01-02-2009, 10:02 AM
usmc320's Avatar
A Y-pipe is what comes from the factory to go from 2 exhaust manifolds to 1 I-pipe that runs over the axle then splits back to 2 pipes. The stock Y-pipe was flattened on the bottom for ground clearance though creating a restriction. People buy Y-pipes to correct that as well as to fit to long tube headers.
The X and H pipes are on true dual systems to connect both sides of the exhaust for scavenging purposes. People tend to pick H pipes for better sound and X pipes for better power. I can't attest to how true this is as I've only used X pipes myself.
Old 01-02-2009, 10:18 AM
thank you sir! The reason I ask this "dumb" question is becuase im investing on a good exhaust but wondering what pipe I should buy. I heard good things about the X pipe. Y pipe is too common. I want to be different. How bout the H pipe?
Old 01-02-2009, 10:22 AM
streetassasin's Avatar
heres my H pipe, Its longtubes 2.5" H pipe dumped dynomax bullets
Old 01-02-2009, 10:23 AM
Build #1's Avatar
LOL! I need something to wipe my eyes...
Old 01-02-2009, 04:02 PM
hmmmmmm I dont like those.........not my sound. Anyone has an X pipe sound?
Old 01-03-2009, 10:37 AM
usmc320's Avatar
I'm running an X pipe through the same mufflers as streetassasin, and it doesn't sound much different than his clip. Although his is louder I'm sure since mine are over the axle and his are dumped.
Old 01-03-2009, 11:02 AM
HMERacing's Avatar
Old 01-06-2009, 07:15 PM
dre2013's Avatar
the sound is b/c of the bullets. go to ls1sounds.com
Old 01-31-2009, 01:58 AM
jcobra99's Avatar
Depends on which mufflers you are using lol. For the best performance you should go with an X pipe. There is nothing better than true duals..other thn open headers
Old 01-31-2009, 02:06 AM
lemons12's Avatar
ms4 cam... pacesetter LT's into custom 2.5 inch X-pipe with 1 chamber race flowmasters..
none of these do the exhaust justice.. in person it sounds 10X's better..
cold start.. it was about 30 degrees out, lopes MUCH harder and deeper when warmed up..
http://s250.photobucket.com/albums/g...t=SD531115.flv
http://s250.photobucket.com/albums/g...stockCobra.flv
http://s250.photobucket.com/albums/g...t=SD531107.flv
http://s250.photobucket.com/albums/g...t=SD531024.flv
http://s250.photobucket.com/albums/g...t=SD531026.flv
http://s250.photobucket.com/albums/g...t=SD531071.flv
and some pics.... sorry so shitty..
Old 01-31-2009, 03:40 AM
00MaroonZ28's Avatar
Here's a run of mine. I have LT's, x-pipe and dynomax bullets dumped before the axle.
http://www.youtube.com/watch?v=d5SUGrO0Ac4
Old 01-31-2009, 10:18 AM
D_Rock's Avatar
dude you should seriously go to http://www.ls1sounds.com/ It will help you decide on which exhaust setup you want. thats how I ended up with my Magnaflow. I usually hate when people say use the search button, but in this case I mean come on bro. There is a plethora of threads explaining what the difference is and so many people asking the same questions over and over and over. There is also a sticky at the top of this page explaining everything you just asked.
Im not bashing you in any way just pointing you in the right direction. Your car looks good too by the way. Later bro.
Old 01-31-2009, 11:40 AM
Strahley's Avatar
Don't choose an exhaust over what you hear from online videos. Find some local cars with similar setups to what you are interested in. Exhaust videos lose a lot of the sound/bass
I myself have heard both X and H pipe dual setups in person, and I prefer the H. It tends to give off more of a mellow tone to it. X pipes tend to give off more of an exotic tone to them, which I don't like as much, as the LS1 already sounds hollow enough as it is. As for power differences, I doubt it would be anything significant. Two near identical cars with the only difference being H vs X, it would be a driver's race
Old 01-31-2009, 11:48 AM
98TAjwh's Avatar
read the stickies dumdumdum!!!
Old 01-31-2009, 04:17 PM
Pharcyde50's Avatar
X pipe vid is in the sig w/ dumped spiral flows
