TD Drone
Old 01-01-2009, 11:30 PM
00cls1camaross's Avatar
Default TD Drone
I have custome 2.5" TDs with dynomax bullets.
I have just shitty drone from 1.3k-2k which is obviously cruising rpm. Then i have drone at 3k rpms.
I did some searching and some people suggested XR1s or MagnaFlow Powerpacks. Anyone have any luck getting rid of drone?
Old 01-02-2009, 01:43 AM
01ssreda4's Avatar
mine drone from 2k-2700 rpm. sucks but whatever.
Old 01-02-2009, 02:26 AM
blackLS1m6's Avatar
You could try facing the turndowns towards each other that may help.
Old 01-02-2009, 07:02 AM
brad8266's Avatar
Run them out the back, that was the best thing I ever did. I love the sound of my car since I ran them out the back.
Old 01-02-2009, 07:08 AM
streetassasin's Avatar
Mine dont drone nearly as bad as my open borla did. Do you have a H or X?
Old 01-02-2009, 09:08 AM
stealth71's Avatar
Bullets on my car were bad up to about 2k. Put some Magnaflow 3" ovals on it and it went away.
Old 01-02-2009, 12:21 PM
SidewayzOZ's Avatar
As said, try playing with the direction you have the turndowns facing, it can change the drone a good bit, but your muffler is ultimately what contributes to it. With 4.10 gears and single chamber flowmasters, the drone is almost non existant. I can't comment on other mufflers because I've never tried them.
Old 01-02-2009, 01:02 PM
I like tie dumped look, if i ever ran them out the back i would do a molded CME. I dont have the money for that now...
i see. so a muffler replacement is what i need. I have an X pipe dynomax bullets and turndowns. All my exhaust is welded up so i cant adjust ****.
So magnaflows made your drone go away? Which ones?
What is your combo everyone?
Old 01-02-2009, 01:22 PM
LS1crazy01's Avatar
I have moroso spiral flow's with the turndowns angled toward the outter sides with no drone what so ever, it is a 3 inch x pipe.
Old 01-02-2009, 03:38 PM
01ssreda4's Avatar
so maybe turning them away from each other is what keeps the sounds waves from interacting with each other so bad?
Old 01-02-2009, 08:55 PM
no i have mine turned away. I think it is a muffler issue
Old 01-02-2009, 09:24 PM
Tech Resident
ChocoTaco369's Avatar
Converting the X-merge to an H-merge will probably relieve a good bit of drone. Personally, I'd throw some Magnaflow bullet-style metallic core cats on there.
Old 01-02-2009, 11:34 PM
TheLSgun's Avatar
Got any sound clips of your car with the single chamber flows. I was think about getting them.
Old 01-03-2009, 09:19 AM
01Z0H6's Avatar
I am running 3in TD's (Lanes) through a custom 3in CME with the "ProFlow 18in Twisters". It is louder @ lower rpm's, and it screams @ WOT, but no drone!
Old 01-03-2009, 12:09 PM
caviness's Avatar
out the back is the only way to get rid of the sound so get used to it or run em back
Old 01-03-2009, 09:07 PM
SidewayzOZ's Avatar
There are a few videos up here:
http://www.camsurge.com/videos/?userId=1
I'm not sure if any of them are decent enough to gauge the sound.
Old 01-03-2009, 09:11 PM
Dustin98SS's Avatar
Running the exhaust out the back IS NOT the only way to get rid of drone. I would replace the bullets with a chambered muffler. Also I have my turn downs facing away from each other and I have no drone at all. I have the magnaflow xl mufflers. I just posted a vid. Check it out. On the highway its like having a stock exhaust!
Old 01-06-2009, 01:23 PM
can i get some more info on these mufflers?
Old 01-06-2009, 01:59 PM
Dustin98SS's Avatar
Summit part # is MPE-13219 Honestly just from MY experiance with any bullet style muffler drone is going to be terrible. Check out the mufflers I have. They are 3 chamber and cruising around town I can hear my radio and also hear myself think Once I added the turndowns it was night and day quieter inside.
Quick Reply: TD Drone
