Crank Bolt removal on Engine Stand
Old 01-05-2009, 08:07 AM
Detroitmuscle's Avatar
Default Crank Bolt removal on Engine Stand
I have my new motor on a engine stand as of now and I'd like to keep it there my problem is that I can't get the crank bolt loosened to remove the balancer and finish disassembeling this motor, any tips? I have already tried using a high powered impact to break it loose with no luck and I'd don't want to remove it to install the flexplate and go through all that is I don't have to. Thanks in advance.
Old 01-05-2009, 08:14 AM
the_merv's Avatar
Might have to put the Flex Plate on it so you can immobilize the Crankshaft and then go back at it.
Old 01-05-2009, 09:48 AM
As I said definatly a last option for me because I still have to pull the cam and valvetrain.
Old 01-05-2009, 09:57 AM
618HAWK's Avatar
Might be able to install 2 bolts in the back of the crank and wedge a bar against the stand. Or even better drill, and bolt a heave piece of steel to the back of the crank, wedged against the stand to bell housing bolt.
I would be very cautious about knocking the whole motor and stand over while trying to brake it loose.
Another option would to use a very large strap wrench on the pulley itself.
Old 01-05-2009, 10:04 AM
jmm98LS1's Avatar
Heat up the washer part of the crank bolt a little with a propane torch to break the loctite free (don't go nuts), then hit it with the impact.....it'll come off like butter. Done it that way many times.
Old 01-05-2009, 11:25 AM
Sounds easy enough I'll give it a try here in a few minutes and let you know how it goes.
Old 01-05-2009, 04:23 PM
Gen3_240z's Avatar
I bought this tool from Summit. I was in the same situation and it worked like a charm for me
http://store.summitracing.com/partde...8&autoview=sku
Old 01-05-2009, 10:00 PM
sman's Avatar
I just poped it off with an impact on my 5.3. Maybe see if you can find someone with a more powerful gun, I had to borrow my dads cause mine wasnt cutting it.
Old 01-05-2009, 11:23 PM
S10xGN's Avatar
Yup, same here & didn't even have to lock down the flexplate...
Russ
Old 01-06-2009, 05:37 AM
The impact I have worked like a piece of cake on my LS1 but not on the new motor as I mentioned, but I'll see if I can't borrow a more powerful one if the heat doesn't do the trick. Thanks for the ideas guys.
Old 01-06-2009, 05:53 AM
Raven02TA's Avatar
ok heres something you could try.... it worked for me.... install 2 longer bolts into the holes where the flexplate would go on the crank.... get a "big bertha" screw driver and wedge it between the bolts, then rotate it so the screw driver is against the engine stand to motor "bolts"....
Old 01-06-2009, 06:24 AM
Got it off finally just took a little bit of heat and a full compressor, thanks guys.
Quick Reply: Crank Bolt removal on Engine Stand
