It breathes again!!
Old 01-07-2009, 07:09 PM
Magic Man's Avatar
Default It breathes again!!
I got done tonight and I want to finish getting it tuned as it sounds good.I did the mod to my 78mm Fast and turned it into 85mm and redid my coil wires back to the cowl with MSD 8.5 and had my after market valve covers powercoated so it looks pretty good and sounds damn good.I've got 5.3 ported heads,230/224 cam from Thunder, Terra rockers.FLP headers.b&b Tri-flow exhaust,mez electric water pump,solid motor mounts,TCI 4400 torq convertor and flex plate,Moser 12 bolt with 3.90 gears,and all the suspention from BMR,Spohn adjustable torque arm.Right now I'm running Hoosers on the rear but they don't hold it any more.
Now to redo some wiring and get ready for this spring.
Old 01-07-2009, 08:07 PM
SS1875's Avatar
Congrats, sounds like it should run pretty good after tweaking the tuning. Good luck with it.
Old 01-07-2009, 08:08 PM
crzytown69's Avatar
