Testing o2 sensors off car?
Im getting ready to finish my build up...again, and my o2 sensors are a bit old and have been sitting around for a bit. Im a cheap bastard though, and if I can keep them I would like to. I was just wondering if there is a way to test them off the car. Anyone done this before?
cannot test them off the car....thats how they work. they sniff the atm inside the exhaust, then take a sample from the ambient air, the diff in oxygen creates a voltage wave form. so if you "test" them in the air....what do you think will happen?
LS1Tech Premium Sponsor
You can test them off the car. You'd need a torch and a multimeter. It's not a perfect test, but you could watch the voltage differential between the two signal wires to ensure they are switching/varying while under the flame. The heat will get them to full temp quickly, and the varying amount of fresh air to burnt propane will actually show a voltage differential close enough to the real thing that you'd get a good idea on their functionality.
You CAN test virtually any sensor off the car if you know what you're looking for from the output from the sensor.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
