radiator support fuse box relocation due to CAI
I had some scrap piping and decideed to make my own intake, but ran into some problems. I need a new radiator support so that the intake would sit a bit lower and for aesthetics.
Also I need to relocate my fuse boxes in order to make it fit better.
I did a search but could not find anything for the rasiator support. Is there a place where I could buy a piece that supports the radiator like with the K&N FIPK? Or does some one have a link or template so I could make one.
I found someone on here who relocated thier fuse boxes by going through the hole right below where they sit. When I pulled mine out, there was something blocking that hole. What is it?
Also is there a different way to do it.
Here is my set up
Here is my set up
Radiator Support: This works on LS1 also, but it is intended for LT1s. I have seen these on many turbo LS1 setups. These two sponsors have them.
After Thoughts Auto (Sponsor)
http://www.afterthoughtsauto.com/pol...r-support.html
BMR Fabrication (Sponsor)
http://www.bmrfabrication.com/misc.HTM
