Crossover for fuel rails in back or front of intake?
Old 01-09-2009, 08:57 AM
Loudmouth LS1's Avatar
Default Crossover for fuel rails in back or front of intake?
Does it make a difference, is it better one way or the other? I noticed lately i've seen a lot of people with the crossover at the back and feed at the front and was just wondering if there was a reason for it, thanks guys!
Old 01-09-2009, 09:26 AM
Magic Man's Avatar
It doesn't matter. I put the cross-over in the back just to keep the clutter down.
Old 01-09-2009, 06:39 PM
03 BUSA's Avatar
Does the back cause any issues with the oil press. sending unit?? When installed in the front it doesn't look right. IMO
Old 01-09-2009, 10:12 PM
Clears on mine.
Old 01-09-2009, 10:22 PM
03 BUSA's Avatar
You run the rear cross over?
Old 01-09-2009, 10:29 PM
I originally had it in the front and then put it in the back just recently when I was trying to fix a problem I had and wanted to rule something out and just wanted to ask if it was ok to leave it like that, that's why I made this post, cuz i've actually since then noticed a lot of pictures with people with it in the back.
Old 01-10-2009, 09:20 AM
Michael02hawk's Avatar
I put mine in the back too, clears the sending unit by far. I figured with my cross-over in the back:
1. It hides the clutter,
2. Its more likely that I'll be dis-connecting the fuel line attachment itself rather than the cross-over. Having the fuel line in front makes it easy to remove.
3. It leaves the plugged end of the rail in front, so it's easy to add a gauge, sensor or other accessory if I wanted one day.
Old 01-10-2009, 08:04 PM
Camaro396's Avatar
I put mine in the front. I think it looks nicer.
