Is LS6 Valley Cover worth it?
I have my motor completely disassembled right now. I am debating buying the ls6 valley cover and grinding down the block to make it fit while it is bare. I already have the ls6 coolant lines. I have never run a catch can and didn't plan on it now. Would it be worth the $60-70 to buy the cover now or should I put the money towards a catch can instead?
I installed the LS6 valley cover. The aluminum shavings go everywhere when you cut that piece out. I did a good job covering things up but I don't think it's really worth the risk of getting some aluminum shavings in your motor. Just my 2 cents.
My block is completely bare. I am in the process of rebuilding the bottom end so now would be the best time IMO because I could clean all the shavings out. Did you have a noticeable difference in oil consumption?
I still add oil between changes. My oil pan gasket is weeping a bit - I lose some there. All I seem to get in my catch can is condensation.
