Underdrive Pulley and Belt
Old 01-17-2009, 10:24 AM
WS.666's Avatar
Default Underdrive Pulley and Belt
If you use a 25% Underdrive Pulley, do you need to get a smaller belt, or will a new stock belt work and the tensioner pulley make up for it?
Old 01-17-2009, 10:31 AM
vsocks1's Avatar
You need a new belt.
Old 01-17-2009, 10:42 AM
Avaric3's Avatar
and its gotta be shorter than stock
Old 01-17-2009, 01:00 PM
PontiacFan's Avatar
For example:
Harmonic Balancer/Underdrive Pulley, 1998-02 LS1 Camaro/Firebird w/Bolt SLP's new 25% underdrive balancer for LS1 F-Bodies incorporates a number of high-quality features you won't find on any other aftermarket unit. Chief among them are a pair of extra-tall belt-retention walls that eliminate the belt-slippage issues endemic to other LS1 balancers (see photo). Other unique design strengths include 100% steel construction (other brands use steel and aluminum), integral timing marks, and built-in puller-mounting threads. Includes a new balancer bolt and detailed installation instructions.
NOTE: Requires 2 new belts (Gates #K060763 and #K040378 or equivalent, not included). For LS1 F-Bodies only.
Old 01-17-2009, 01:42 PM
01ssreda4's Avatar
agreed, no way a factory belt would work
Old 01-17-2009, 07:35 PM
devinfbody's Avatar
What about a 10% underdrive? Figure the stock belt size will work with that?
Old 01-19-2009, 11:59 AM
Golf&GM's Avatar
No way, both the accessory and AC belts have to be right on with the size. Too big and you'll throw them all the time, too small and they'll wear out way too fast.
Quick Reply: Underdrive Pulley and Belt
