Where did i go wrong
Old 01-21-2009, 05:46 AM
Naf
Naf's Avatar
Default Where did i go wrong
I own a 2005 CTS-v (still brand new) and i installed the followin parts on it
FAST 90/90
GMPP high compression heads
Yella Terra 1.7 rockers
7.4" pushrods
GMPP lifters
LPE GT11 cam
LPE High Flow Oil Pump
LPE CAI
SW 1 3/4" headers
2.5" Ti Corsa Catback
Matrix High Flow Cats
25% UD pulley
I made 367hp on a mustang dyno and well, i am gettin plenty of laughs from my setup and now my numbers. Torque is not available due to rpm pickup not workin...
Should i increase my Valves from stock LS6 to 2.055" and 1.570". The car feels great on the road, and i am gettin a nice mixture all across the board...
Please help, i am actually lookin to shave off weight, but increasin the HP is a nice thought...
Btw my engine compartment is VERY tight so a vararam spacer is out of the question. Rad is in the way.
Old 01-21-2009, 07:08 AM
outkast6991's Avatar
run the car at the track and see where it mph's. dyno's are for tuning not judging a cars power level. my car which is obviously very different from yours put down anywhere from 315 to 355 depending on the dyno but runs in the 11's @113-116 depending on weather.
Old 01-21-2009, 07:46 AM
03Sssnake's Avatar
Don't get wrapped around the axles on your numbers, they aren't everything, take her to the track .. BTW, was the car tuned? I would look into turning off the power/torque management feature if it has not been done.
Old 01-21-2009, 08:13 AM
Naf
Naf's Avatar
I dont do quarter miles, i do circiuts. I have to admit anything above 1000rpm she pulls me back and keeps me pinned right up to red line.
I personally tuned it, i will look at disablin the torque reduction. But i am usin EFILIVE.
Will playin with the perdicted airflow help boost up the power?
i am runnin 12.8-13.1 at WOT
Old 01-21-2009, 08:34 AM
bluehawk2's Avatar
that's bout what my car made on motor with ported 243's, comp 232/236 595/601 112+2.
1 3/4 long tubes 25% underdrive pulley & TR6 plugs for nitrous
Mine made around 370ish with the converter unlocked through a 12bolt.
For comparison.........Cam only my ride made 403 wheel on a dynojet, but that was with the converter locked and it was a dynojet.
don't worry about the numbers.......if it feels good and runs good times, then who cares about the number
Old 01-21-2009, 08:37 AM
bluehawk2's Avatar
shouldn't this be in the dyno comparrison section
Old 01-21-2009, 08:49 AM
2002_z28_m6's Avatar
If it doesnt trap some healthy mph. I would suspect it is in the tune.
Old 01-21-2009, 01:17 PM
deadmanTA's Avatar
Mustang dynos always show lower numbers. Put it on a dynojet and I bet it would be closer to 400rwhp.
Old 01-21-2009, 03:34 PM
one fast zo6's Avatar
Default help
your tune is OFF and that CAM is way weak!
Old 01-21-2009, 05:09 PM
j0694 ws6's Avatar
should be making more power than what u said id figure around 400
Old 01-21-2009, 05:32 PM
Sicko's Avatar
I made 411rwhp on a unlocked converter on a cam and boltons only ls2. You should do better then that.
Old 01-21-2009, 11:42 PM
Naf
Naf's Avatar
I have a Manual tranny. So no convertors...
In the end there is a loss of power somewhere. Will look to the torque reduction and other means where the pcm may reduce the output.
Thank you all for your help
Old 01-22-2009, 08:33 AM
slp--firehawk's Avatar
dont forget to make sure you are properly tuning your ignition advancing map, that is a CRITICAL part, equally important as the air fuel mix. Changing it also will change the air fuel mix as read by your computer, and could make it look fine or good when it is pretty far off, so make sure you really know what your doing tuning yourself or else you wont be getting the power OR efficiancy and it will look like it is running dandy
