My catch can routing ok? - Page 5 - LS1TECH
Thread Tools Search this Thread
Old 02-16-2009, 11:46 AM   #81
Quote:
Originally Posted by 98Camarod View Post
I'm going to order a saikou michi catch split dc3 and do the last setup that you are suggesting for turbo applications. Is the only way to order them is through there site or is there a sponsor on here that sells them?
I'm curious why people use vented catch cans or put a breather on the valve cover. That opens the system. It either needs to be completely closed or completely opened with nothing going to the intake, otherwise the crankcase is pressurized.
Lot of good info in here. Thanks again for your time!
If you do NOT have a filtered fresh air source to flush out the caustic combustion byproducts, unburnt fuel, and moisture you will sustain internal damage over time as every time you shut-down and the engine cools all these flashed off harmful vapors will recondense back into the crankcase.
On a race only engine the oil is changed after every few races so it is not an issue, and we generally use a crank driven vacume pump and a vac relief valve. These engines are torn down & rebuilt every season also. A street motor MUST have filtered fresh air pulled through the crankcase to perform all the functions of a proper PCV system.
TLewis4095 is offline   Reply With Quote
Old 02-16-2009, 12:20 PM   #82
98Camarod's Avatar
That filter performs the same function as the catch can does. All of the by products that would be left would still be there even with the filter, that's not a convincing reason to use a breather; opening the pcv system which is supposed to be closed
98Camarod is offline   Reply With Quote
Old 02-16-2009, 02:20 PM   #83
System is never closed....OEM it pulls filtered air from the main air filter through the throttle body, so all your doing is changing it so no oil enters the intake due to reversion pulse. Look at the stock routing carefully and it is easy to understand it.
If you plug off the stock source of filtered fresh make up air there is NO flushing of the crankcase. But you can run yours anyway you choose, just so someone uninformed does not follow it and end up with damage over time.
Old 02-16-2009, 08:01 PM   #84
PowerShift408's Avatar
Thanks so much for the informative posts. Just sent an e-mail to Mr. Michi to get a dual catch can setup. This is what I've always thought was needed for these cars.
PowerShift408 is offline   Reply With Quote
Old 02-17-2009, 05:59 AM   #85
I have a stock 1998 LS1 from a camaro, and I want to rout an oil catch can to the best way possible, any links or information?
Thanks
wajouba is offline   Reply With Quote
Old 02-17-2009, 10:12 AM   #86
405HP_Z06's Avatar
Quote:
Thanks
Read the thread......post 70 has diagrams
http://www.ls1tech.com/forums/11059703-post70.html
405HP_Z06 is offline   Reply With Quote
Old 02-17-2009, 07:43 PM   #87
Sent you a pm.. can you please explain a few things for me??
2002RamAir is offline   Reply With Quote
Old 02-17-2009, 07:58 PM   #88
405HP_Z06's Avatar
Quote:
Responded.
Old 02-18-2009, 02:20 PM   #89
so if i have a valley cover with a port. i dont need ports in my valve covers? and what do i do if i have a twin turbo. and even thought i have a turbo set up can i get clean air from my intake manifold?
thanks
Big Bird WS6 is offline   Reply With Quote
Old 02-18-2009, 02:24 PM   #90
if it helps i have a ls2/3 valve cover. thanks
Old 02-18-2009, 09:17 PM   #91
405HP_Z06's Avatar
Quote:
thanks
Diagram from above:
You can put the fresh air hose in front of either turbo, doesn't matter. The intake manifold connection is for the dirty side.
Old 02-19-2009, 06:55 AM   #92
and how to do duel can. got alos of horse and does that matter?
Old 02-19-2009, 07:34 AM   #93
405HP_Z06's Avatar
Old 02-19-2009, 11:22 AM   #94
sorry it is more that i want to make sure it is perfect. you said i can put it to eith turbo. well can i go to the manifold? or what is the importance of before the turbo? also once it get pressure before the turbo wont it suck air out of the clean side?
Old 02-19-2009, 03:10 PM   #95
98Camarod's Avatar
Do you not know how to read? If you return it to the manifold then it will pressurize the crankcase under boost.
Old 02-19-2009, 03:18 PM   #96
03supercobra's Avatar
So i have a Revextreem for my valey cover, what one should i get to go from my valvecover to T/B? Preferable a small one.
03supercobra is offline   Reply With Quote
Old 02-19-2009, 05:38 PM   #97
garygnu's Avatar
can the air pump be programmed to run when the engine is running and serve as a vacum pump in the pcv system ?
garygnu is offline   Reply With Quote
Old 02-19-2009, 10:37 PM   #98
but where it is suppose to be getting clean air, will start sucking air on boost
Old 02-20-2009, 12:02 AM   #99
405HP_Z06's Avatar
The diagram is based on the LS1 PCV configuration, but the concept is the same.
Old 02-24-2009, 10:34 AM   #100
aaron,
i will try this. and let you know. thanks,
but if i have a ls2/ls3 valley cover with the port in it. i dont need to get valve covers with back ports? i can buy ones with out?
thanks
Related Topics
Thread Thread Starter Forum Replies Last Post
Catch Can Questions Rise of the Phoenix Generation III External Engine 10 02-08-2017 08:47 AM
My Procharger PCV Setup Okay? Camarokid327 Forced Induction 6 05-17-2016 03:12 PM
Pcv catch can routing help needed, PLEASE slammin sammie Generation III External Engine 2 03-12-2016 06:07 AM
Carb ls2 pcv system dropped72ss Carbureted LSX Forum 15 07-07-2015 05:17 PM
my catch can setup extremetoy Forced Induction 6 02-02-2009 02:29 PM
Tags
amw, c6, cans, catch, corvette, cover, dc3, ebay, ls1, ls1tech, oil, pcv, routing, tapping, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
