3" duals under axle on 1.75" drop?
Old 01-25-2009, 01:27 PM
mastercoryd's Avatar
Default 3" duals under axle on 1.75" drop?
hey guys, i wanted to do some 3" true duals under the axle i seen some tucked up pretty good, would this fit fine on camaro dropped almost 2" on g2 springs? or shall i have to go to 2.5?
Old 01-25-2009, 01:35 PM
Tech Resident
ChocoTaco369's Avatar
What's your power level? If you're making under 550rwhp, there's no reason to go 3" over 2.5" If you're not making anywhere near that power, you'll benefit from 2.5" duals as there is more than enough flow and the lower volume will maintain better exhaust velocity, adding to power.
Old 01-25-2009, 03:51 PM
jmm98LS1's Avatar
What? You do know that 550rwhp is close to 675hp at the flywheel.....the best 2.5" duals on the planet won't even come close to supporting that kind of power. Good 2.5" duals can support up to ~500fwhp (~430rwhp) before becoming a restriction, it's been tested over and over.
To answer the OP's question, it all depends on how you run the exhaust. I don't know that I'd try to go under the axle being lowered that far. Dumping it would be far easier, but if I had to go out the back I'd take them both over the passenger side.
Old 01-25-2009, 10:14 PM
Tech Resident
I meant bhp. Force of habit typing rwhp. The point is, 2.5" duals will outflow 3" catbacks easily, and since there are plenty of people in the 10's and 11's running catbacks, 2.5" duals are more than enough for most applications. There is no point on going to 3" duals in most cases.
Old 01-25-2009, 10:30 PM
00cls1camaross's Avatar
if you think of it... the body is lowered 1.75" not the axle. Axle clearance is axle clearance. I have seen a couple of under the axle setups on big drops. 2.5" TDs and you will be good.
Old 01-25-2009, 10:42 PM
1979rs/z28's Avatar
I was thinking exactly the same.
Old 01-25-2009, 10:54 PM
NBM-LS1's Avatar
I just finished up on mine tonight. TA on Sportlines and Bilstiens with a 3" system, under axle, out the back.
Ill post pics later.
Old 01-26-2009, 02:12 AM
2000Hawk's Avatar
Mind if i ask how much did they charge you? Also did you have it dumped and continued out to the rear, or have a complete set-up made? Thanks
-Joel
Old 01-26-2009, 01:55 PM
dug
dug's Avatar
I was thinking the same thing. The only thing would make a difference is tire height
Old 01-26-2009, 02:51 PM
budz01's Avatar
Default thansk
thanks a lot i got something new here, i know what im going to do to my car
_______________
Busby SEO Test
Quick Reply: 3" duals under axle on 1.75" drop?
