people with true duals, what tq arm are you using?
just curious to see what kind of aftermarket torque arms you guys are using with true duals and x pipes. pics are a plus, thanks!
Re: people with true duals, what tq arm are you using?
no kidding! i was actually wondering about the spohn tq arm, im glad to know it fits! do you guys have just the regular tq arm, or the one with driveshaft loop(s)? also, did you have to route the exhaust pipes around the tq arm, or was that not necessary? any pics? thanks!
Using the BMR track pac tq arm here, The crossmember is now bolt on instead of weld on but this was the only modifications made.
Here is a couple links
http://www.badrap.net/members/Devil505/Exhaust/
and
http://home.tampabay.rr.com/mk/true_dual_exhaust.htm
The 2nd link is my car but the pics kinda suck. The first car was done the same way and the pics are better.
and
7 Second Club
I'm running the Spohn TQ arm with my TD.
LS1TECH Sponsor
I HIGHLY recomend a tunnel mount torque arm, one that you bolt into the tunnel (if you don't mind drilling). It will give you a TON more clearance. I'll have to get pics of my setup soon.
The MAC tunnel mount torque arm comes with a DS loop and is only around $300.. Only bad part is its non-adjustable.
click the link to pics of my Kook's custom true dual setup with spohn torque arm. Since that was done I've added tails that go over the rear an tip's it was too loud exiting under the car with dump's after the head an cam install
http://www.fastls1.com/forums/showth...;threadid=1765
MASS seller approved
Is that 2.5 or 3 inch true duals?
Thanks
and
and
What brand of mufflers are those?
Those look like 2.5's. BTW, very nice installation, Tom! Looks like you have much better ground clearance than most people with true duals.
