Z28 hooker longtubes?
Old 01-26-2009, 12:40 PM
godzillals199's Avatar
Default Z28 hooker longtubes?
Hey all i wanna get some hooker long tube header for my 99 T/A just wondering if they will fit. They are off of a 98 Z28
thanks
Old 01-26-2009, 02:55 PM
Unertl42's Avatar
yes, they should fit
Old 01-26-2009, 03:11 PM
z16kalel's Avatar
Went in with no problem, had the car lifted 23 inches in the garage.
Old 01-26-2009, 04:07 PM
well what about this the cats and y pipe is welded to the headers what do you think the odds are of getting them in with out a lift?
Old 01-29-2009, 02:27 AM
5.slow99's Avatar
its possible its just gonna take a lot of moving around and a lot of " i hate this car" how high can you get it?
Old 01-29-2009, 03:22 AM
jcobra99's Avatar
Ill pray for you
Old 01-29-2009, 02:02 PM
FiredUpZ28's Avatar
I installed Hookers without a lift or a tall jack (didn't have a jack that went over 20") . Just jacked up the engine a little bit and took the steering shaft out. Went in from the top no problem. Car had no A/C though - definately helps. May even be the breaking point on whether you can do it from the top or not.
Old 01-29-2009, 04:10 PM
99bowtieZ's Avatar
Originally Posted by jcobra99
Ill pray for you
It is definitely possible because the hookers will go in and you will be able to pretty much slide them straight up(Pass. Side). As for the drivers side.... I'll pray for you too.
