installing solid motor mounts??
Old 01-31-2009, 12:34 PM
SS4Luck's Avatar
Default installing solid motor mounts??
so all the install rants and instructions ive seen are for poly mounts. how muc harder are solids?? i konw they process will obviously different and im wondering if this is something ill be able to tackle in my garage
please chime in if you have installed solids. if you have polys keep your opininos to yourself
Old 01-31-2009, 03:14 PM
Ironxcross's Avatar
I'm thinking they're on the same level of PITA, but you don't have to drill rivets out.
Old 01-31-2009, 03:36 PM
drummydummy's Avatar
The hardest part doing my prothane engine mounts was lining everything back up (matching the mounts to the block and the k-member. That was a major PITA!!!
Like ^ he said it would just eliminate the step of re-building the stock housing with new mounts so there wouldn't be any torching, drilling, grinding and other fun stuff!!
If you don't mind the extra noise and vibrations from the solid mounts, go ahead.
Old 01-31-2009, 04:32 PM
TheSilverOne's Avatar
there is no "noise" from solid mounts. i have very minimal vibration under 1000 rpms and thats it.
Old 01-31-2009, 04:37 PM
Lt1Porsche's Avatar
Installation for solids is no where near a PITA like poly's. Solids take about 30 mins to put in given the headers and removed.
Old 01-31-2009, 10:27 PM
Magic Man's Avatar
Are you on your back or have a lift.I have a lift and they were not hard at all and no rockin and rollin from the engine.
Old 02-03-2009, 12:44 PM
SS4Luck's Avatar
ill have a lift make things nice and easy
i ordered my solids yesterday and should be tackling the project this weekend
Old 02-03-2009, 01:03 PM
omcar's Avatar
Where do you get the solids from?
Old 02-03-2009, 01:23 PM
NeedaV8foundation's Avatar
ws6store
Old 02-03-2009, 02:25 PM
NemeSS's Avatar
whats wrong with the poly,
ive never had solids on a street car
Old 02-08-2009, 04:24 AM
metalmechanic's Avatar
solids are kool, got mine from spohn. but when letting out the clutch in mild city driving the vibes resonate throught the car till about 1,200 rpm
Old 02-08-2009, 06:05 AM
warp10's Avatar
I've had solids and went back with poly. Solids are too noisy and creates too much vibrations.
Old 02-09-2009, 12:27 AM
SS4Luck's Avatar
my solids will be here thursday got them from lmperformance and have buddies all lined up for the job at hand this weeekend. Cant freaking wait lol
i dont mind the vibrations or noise, its why i have a big cam right
Old 02-09-2009, 12:34 AM
1999FirehawkLS1's Avatar
I have solids and i used to have polys in a older car and i like these solids i cant really tell but i have dyno matt threw my floor
