317 heads with Lsx intake??????????
Old 02-02-2009, 11:07 PM
71 chevelle's Avatar
Default 317 heads with Lsx intake??????????
I have or so I was told a 2006 6.0l (block # 12551364) from a escalade. It has 317 heads and would like to run a ls type intake what intake and what would I need to make this change. this motor is going in a 71 chevelle.
Thank you.
Old 02-02-2009, 11:57 PM
eviltwin_1987's Avatar
Old 02-03-2009, 10:50 AM
conan's Avatar
You can run a ls6 intake or any of the fast intakes. They will fit on the 317 heads. Not sure if the fuel rail and throttle body can be reused.
Old 02-03-2009, 11:05 AM
NemeSS's Avatar
just leave it as is, the truck intake flows very good, even better than the fbody ls1 intake, plus u can keep all the stock fuel rail and inj., my have to use a return type fuel rail if not equipped with alredy
Old 02-03-2009, 11:10 AM
CodeRed2000SS's Avatar
even better than a FAST?
Old 02-03-2009, 11:15 AM
NemeSS's Avatar
no way,
but the truck intake is pretty close to the oem ls6
Old 02-03-2009, 11:25 AM
thats what i thought. the guy above had me confused a little bit. im pretty sure the truck intake does flow as good. but i knew it wont better than a FAST.
