LGM Tubes, block air tube or not, who sells o2 extenders ?
The intake must come off to properly install the air tube mod required on pre-2001 corvettes...but i have read that you can "block" it...are there any down sides to this - is it easy to do ?
Also i checked the threads & does anybody know who sells the o2 extenders i need?
BTW anybody got the LGM's (no cats) on a soundfile ?
Re: LGM Tubes, block air tube or not, who sells o2 extenders ?
I have the LGM's on my car with no cats and borla 4 tip stingers. The AIR does not need to be hooked up as it is now completely useless if you aren't running cats. LGM will make you some nice little block of plates that go on the AIR tube on the headers. You can then remove all the AIR tubing, and the AIR pump. You shouldnt need 02 exntenders as LGM will send you adapters that allow you to hook up your rear 02's to the front 02 harness. This gives you more than enough room to run the wires to the headers. Let me know if you have any other questions.
Thanks man...how loud is it ? Do you have a clip ?Thats the first i heard about the 02 "adapters." What is the AIR tubing /pump actually for ?
How was the install ?
