Problem with cruise after install of 92/92
Old 02-08-2009, 06:04 PM
ricernomore's Avatar
Default Problem with cruise after install of 92/92
Well I was wondering if anyone has had a prob, or noticed the cruise acting up afterwards. When I try and set the cruise at lets say 80mph it will drop down to 75mph and stay there and I have to tap the gas to help it get back up to 80. Not just in this range either, same every speed i try. Just wondering?
Old 02-08-2009, 11:58 PM
5.slow99's Avatar
i did a 90/90 dont know how much diff it is but i had no problems with the cruise.
Old 02-09-2009, 12:11 AM
SS1875's Avatar
You might have some slack in the cable, try adjusting it out(slide adjuster) and see what happens.
Old 02-09-2009, 01:53 PM
tightened it all the way already
Old 02-09-2009, 02:13 PM
Detoxx03's Avatar
Have no clue man. I tried mine out and it worked fine
Old 02-09-2009, 03:04 PM
01Z0H6's Avatar
Mine also works fine...
Does the Throttle blade stick @ all??
Old 02-09-2009, 04:45 PM
no but I also noticed a little loss in throttle responce, but I guess that could be due to my set up sufficating thru the suncoast creation ram air setup.
