under drive pulley
Old 02-10-2009, 06:39 PM
ls1leadfoot's Avatar
Default under drive pulley
are they worth the money>>>?????
will my battery run down faster and have more draw on it during city driving....will anything wear out early like the power steering pump??
and are they really something i should even consider putting 200 bucks into
what to do and which one should i buy
Old 02-10-2009, 06:47 PM
allngn_c5's Avatar
First question a4 or m6 ??
Old 02-10-2009, 06:52 PM
oops my bad m6 lq4 hci spray full suspension
Old 02-10-2009, 06:53 PM
allngn_c5's Avatar
I have a 2000 FRC which only comes with an m6. I have an asp ud pully, and ewp. With that being said I have never had an issue with charging the battery, or too much draw, but I also don't have any amps/speakers either.
Ud pullys, and EWP's don't really show a lot of hp on the dyno, but they do free up power by reducing parasitic drag. You will also see an improvement in gas mileage under normal driving, especially on the highway. I went from an easy driving 29 mpg (stock 346) expressway to a best of 34.5 mpg highway(h/c/e/i)with the ewp and pully coming back from LG Motorsports. This was in 2006 when I still had a 346. Don't know what the 402 is going to get as far as gas mileage. On the topic of your power steering pump, it should actually extend the life of it because its still turning fast enough to create the assist of the steering that it was intended to, but is actually spinning slower (less wear on it) so in theory it should last longer.
Old 02-10-2009, 07:02 PM
allngn_c5's Avatar
I am sure that you will be fine as long as your alternator is working properly and you don't have 50000 watt amps and 10 15" subs (LOL) J/K, you should be able to get away with a decent stereo too. Just keep an eye on your voltage. If your idle is too low to hold the charge then you can always turn up the idle rpms a bit to coax a bit more juice out of your alt so you don't have to worry about the dreaded dead battery. For the record my car usually showed 13.1 amps at idle with radio, lights, and a/c on. Idle was 1025 rpms on the 346. Not sure what the new 402 idles. At start up the display would show 14.0 / 14.1 or so and then settle back and show 13.0/13.1
Hope this helps.
Old 02-10-2009, 07:03 PM
ok i will buy one lol
just needed a little kick in the *** to do it....my brother swears by them so i might as well huh
thanks man
btw your ride sounds bad ***!!!!!
Old 02-10-2009, 07:05 PM
allngn_c5's Avatar
thanks man
Theres a video of it on LG Motorsports website, or you can watch a larger pic video of it on youtube. Thanks and you are welcome. Good luck.
Old 02-10-2009, 07:12 PM
johnLs1camaro's Avatar
just wondering why would it matter if its a underdrive pulley?
Old 02-10-2009, 07:13 PM
where you at in indiana??????
Old 02-10-2009, 07:17 PM
southern, indiana.. close to louisville ky. is greenwood further north?
Old 02-10-2009, 07:21 PM
allngn_c5's Avatar
Just remember reading several threads about guys with a4's complaining about charging issues. I don't recall ever hearing about any of the m6 cars with issues except this one guy that had a HUGE stereo system pulling a lot of juice. Come to think of it, not sure why it would matter. Just what I've seen.
Old 02-10-2009, 07:23 PM
thats cool man, i didnt know if that was the case either thats why i asked. ive been thinking about getting one for my auto so i didnt know?
Old 02-10-2009, 07:34 PM
ya prob about a hour from clarksville or so
Old 02-10-2009, 07:38 PM
o thats not too bad i thought greenwood was by indy. yeah i live right by new albany actually if you know where that is? you come out this way that much?
Old 02-10-2009, 07:39 PM
i work down south all the fing time....but ya i have about 10 guys that would like to pack up and head down south....i have actually heard that louisville is off the hook sometimes
Old 02-10-2009, 07:42 PM
yeah man louisville isnt bad at all.. the car scene here is pretty good too! there is a lot of ricers but i guess you deal with that everywhere.
Old 02-10-2009, 07:44 PM
Chrome355z's Avatar
I like the ATI unit, expensive bastard though...
oooooh ya,....hell i;ll get ahold of ya man....we will roll down there and cause trouble>.LOL
Old 02-10-2009, 07:46 PM
hell yeah im sayin! i got a few other fbody buds around here so it should be good time.
Old 02-10-2009, 07:59 PM
Detoxx03's Avatar
SLP pulley here and no issues
