F*****G Holley... MAP Sensor Issue
Old 10-11-2003, 05:01 PM
PacerX's Avatar
Default F*****G Holley... MAP Sensor Issue
OK, I have to dick around with having a close-out plate made for this intake (aluminum Holley), the polishing job SUCKED, and now this:
The MAP sensor is supposed to plug into the back of this thing, but the hole is too big for my MAP sensor (it'll fall out).
Do the pre-2001 LS1 intakes have a larger hole in the manifold for the MAP sensor?
Are the MAP sensors interchangeable from 2000 to 2001?
If I have to weld this thing up and redrill it, I swear I'm going to drive down to Holley's headquarters and give somebody an enema with this intake.
Oh yeah...
HOLLEY SUCKS.
Old 10-11-2003, 05:20 PM
Scalpel's Avatar
Default Re: F*****G Holley... MAP Sensor Issue
Yes, the MAP sensors are interchangeable. The holes should be the same size.
Old 10-11-2003, 11:39 PM
slyws6's Avatar
umm I didn't have any problems with mine, ya the sensor does not fit as snug, but the kit comes with a screw that holds it down, screw it in , tighten it up and no leaks.
-Sly
Old 10-12-2003, 10:36 AM
PacerX's Avatar
Sly,
My sensor has no lug for the screw to go through, am I missing something?
Quick Reply: F*****G Holley... MAP Sensor Issue
