Identifying a true LS6 intake????
Old 03-06-2009, 02:47 PM
SilverStang00's Avatar
Default Identifying a true LS6 intake????
What is the easiest way to determine if an intake manifold is truly an LS6? I would imagine some sort of casting # and what not but anything else? Obviously no E.G.R right?
Old 03-06-2009, 03:46 PM
cowboysfan's Avatar
take a look at the frontend underside of the intake (just under the throttle body) should be flat from oneside to the other. LS1 will have a dip.
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
Old 03-06-2009, 04:12 PM
Awesome man, thanks.
Any other dead giveaways?
Old 03-06-2009, 04:18 PM
demarco313's Avatar
and yes casting #. But some you can get with E.G.R. so that means nothing as far as differentiating them. Easiest way by far is to get the casting #. If you know it i can tell you if its a ls6 intake
Old 03-06-2009, 07:11 PM
SS1875's Avatar
- The Ls6 intake has many different part numbers buts its the same intake
- The only way to tell 100% if you are buying an ls6 intake, especially used is to ask for pics of the bottom. The vette LS1 intake does not have an EGR provision so its easy to pass that off as an LS6 if you are none the wiser. Check the website below.
http://www.thedetailzone.com/LS6%20Intake.htm
Old 03-06-2009, 08:55 PM
allbaugh_04's Avatar
Yep, check under the intake, should be flat
Old 03-18-2009, 11:44 AM
99Hawk6spd's Avatar
Just found this, would this be a common enough question to sticky? There are pretty good answers here.
-Gary
Old 03-23-2009, 01:37 PM
I think it might be sticky worthy. Considering how many of Fbod guys do this swap(90% of pre 01 owners I would say)
Old 03-24-2009, 12:47 AM
gun4hire's Avatar
Its already in the sticky titled: "Mod Guide: Induction and Exhuast (PLEASE READ BEFORE POSTING)"
Quick Reply: Identifying a true LS6 intake????
