MAJOR pacesetter longtube header problem!! come in!
ok guys id say ive had these hearders about a year and a half... now before i go any further im am not making this post to bash or attempt to hurt there sells! what i am doing this for is looking to see if anyone else has had this problem ever i would have never thought this would have happened ever until i poped the hood to change the gasket today! the passanger side of the 2000 camaro ls motor is what i am working on the 2nd or 3rd primary where the egr used to mount the stew coming off the header has complety blown off and there is a quarter sized hole there! has anyone else experienced this just trying to find out what to do? will deff be calling pacesetter monday to speak with someone and hopefully they will help me 100% which i feel they will due to it being a weld blowing out that shouldnt imo... anyones input is helpful lets hear it thanks guys! am trying to post pics but not working will continue trying
i have seen this before on here plenty of times.
i have had mine for about 4-5 months and mine have braceing around the air and egr tubes that i havent seen on any others so maybe its a new thing they started?
just weld up the hole.
I had it happen on both sets of PSs I've had. Either get the race header or weld a patch over it with a piece of stainless steel and it won't rust. I did the stainless patch about a year ago and no rust or problems since.
thats what im going to have done tomoroow just a heads up i spoke with pacesetter and they said that if it happens in less then a year they will replace them and you just keep the old headers
no the 3rd primary tube off the header you can see the hole in the pic i attached click it... the guy fixing is is going to grind the hole out to a almost perfect circle put a patch in shape it to the curve of the header and tig it in place
Just happened to me on my drivers side the other day. I had the EGR version but with blockoffs so that could have contributed. Going to have it welded this week. Lasted me 3+ years of abuse.
So why is there a blockoff on the front hole in the picture isnt that the fron 02 bung? And is the hole were the egr also the hole that the air is im still confused?
Here is what I have and they will go on shortly I need front o2s and I would like to eliminate egr and Air from these headers what needs to be cut and welded shut?
This is the second thread in just a couple days with the same topic, and within each thread there are so many people saying, "Hey that happened to me too."
What kinda bullshit is this? I can't believe these headers are doing this. If this happens to mine you better believe the manufacturer will hear about it. This is obviously an issue that needs attention.
If you haven't contacted Pacesetter, PLEASE do and tell them this is a very common problem that apparently needs dealt with.
