catback vs muffler swap
Old 03-19-2009, 07:14 AM
WS6 MIAMI's Avatar
Default catback vs muffler swap
Please help me... I have a 2001 WS6 with long tubes and a ORY. It is attached to my stock catback. I want a better sound and less restriction. What is the difference if I replace just the muffler with a magnaflow muffler vs buying a complete catback. Oppinions please!!!
Old 03-19-2009, 08:08 AM
CodeRed2000SS's Avatar
not really a difference if you get the same magnaflow muffler. Magnaflow is a great choice by the way!
Old 03-19-2009, 08:46 AM
Pontiacerator
RevGTO's Avatar
Catback gives you 3" in, dual 2.5" out. Using a muffler with your stock pipe is 2.75/2.25" in/out. So a little better flow with the catback.
BTW, Hooker makes both the catback size muffler and the stock replacement. Thunder Racing carries both. I have catback size muffler only on my T/A with fabricated 2.5" tailpipes.
teke184's Avatar
2.75" compared to 3" is a 16% increase in diameter....so pretty considerable amount of flow.
i say go for the catback
Old 03-19-2009, 06:03 PM
WS6 MIAMI's Avatar
Thanks for the info. Catback it is!
Old 03-20-2009, 02:12 PM
w3s1c0a5t's Avatar
Or you could just re pipe from the Y. Probably cheaper...
Old 03-21-2009, 08:45 AM
LS1 Sounds's Avatar
Keep the stock catback and add an electric cutout. Best of both worlds, and cheaper. Replace the Y with 3" pipe all the way to the cutout when you have it welded, then stock pipe behind it.
Old 03-21-2009, 01:26 PM
MonmouthCtyLS7's Avatar
I had a 01 ws6 catback w/ a high flowing dynomax superturbo muffler...I swapped it for a LM1 and felt and instant sotp gain along w/ a great sound
Old 03-21-2009, 10:43 PM
WS6 MIAMI's Avatar
re-pipe ... Great idea!
Old 03-22-2009, 12:38 AM
w3s1c0a5t's Avatar
Was that sarcasim?
Old 03-22-2009, 10:28 AM
omcar's Avatar
I have just the muffler #12267..check my sig...it works.
Quick Reply: catback vs muffler swap
