oryp with lowered car?
I did a search but came up empty handed . What kind of ground clearance do you guy's have as I was thinking about lowering my car . Anyone have any pics?
Re: oryp with lowered car?
I scrap mine once a week, and I have a hooker ory and a prokit that sits really low. If you want some pics I can get one up in 5 mins let me know. FWIW its a good idea to lower the car. drive careful and you wont have any problems at all
My car is lowered 2 inchs and my oryp never hits the ground or the floor pan now that I modified it; it used to hang lower than the SLP SFC's, but now it's above them. I cut two sections out of the floor pan reinforcements to clear a path for the Y, then installed QTP headers which brought the Y up very close into the two cut away areas. I plan to weld a U channel on top of this area under the carpet soon to restore chassis integrity. I'll post some pics tonight.
I'll take some pics under mine when I get a chance. I've got the pro kit and the Hooker ORY. I never drag mine. Of course I'm careful about where I drive too. The only thing I've dragged was my cut out once when I wasn't paying attention and went over a hump to fast. Sucked too because it hit right on the wingnut and tightened it down so tight that I didn't think I was going to get it off.
The Hooker ory tucks up very well and should not cause minimal issues if any. SLP headers hang kinda low and I'm not sure about qtp/kooks.
LS1Tech Administrator
Received 1,468 Likes
As long as you have 3" between the Y-pipe and the ground you should be ok. I have exactly 3" and I don't really have any issues except for once coming out of a parking lot that was like a ^ (meaning long ditch-quick peak-ditch again, if that makes any sense. Also, it only happened once with a very large friend in the car (250+ lbs). Never happened again (even on the same parking lot exit without that extra 250 lbs.
