Going from BBK IM and Stock TB to 92/92 setup...
what kinda power gains do you guys think I'd make going from my BBK SSI intake manifold w/stock TB to a 92/92 setup (Fast and Nick Williams)?
mods are in my sig/sig pic
although I hate even imagining paying for that overpriced piece of plastic gold... it's really one of the only mods I have left on the table for this engine...
then my money will go elsewhere...
or u could also upgrade injectors. I had a friend who picked up 50rwhp on dyno with a retune after fast intake, 48 lb injectors and a 255lb fuel pump. Car was way faster. before different intake and mods he was at like 425 rwhp
but if I add cats the the LT's and find a "dirty" emissions shop... that won't look at the whole "visual inspection" then if my car will perhaps pass the sniffer, hopefully I won't have a problem...
my cam 224/224 .581 .581 114LSA
vs.
your cam 228/230 .588/.592 112 LSA
If you are not going over 6500 with that cam , I dont think I would swap.
I seen a better dyno number with my ported fast 90 over my ls6 ported tb but never ran better at the track.
I may put a ls6 intake on my Trans am again and use the Fast 90 on my nova that spins to 7200.
I think bbk makes a 85 mm tb for that intake and so does Summit/trickflow . That is what I would do and just stay with the bbk.
def port it
and with your power levels....on a 6L engine...you should EASILY see 20hp
as i've posted many times...i got 18hp at 6300rpm over my ls6...and i was making less than 400rwhp.
i have no doubt you'll pick up power in the lower rpm as well....like i did.
yea I dunno... $640 for 10hp (is that RW?) is kinda steep...
http://www.speedinc.com/cont.cfm?cid=C0000066
got mine from summit for about $580 i think.
it is pretty pricey...but like YOU said...you're running out of things to modify for power.
engine will run cooler, and you'll gain from power
youll prob see a 10 to 15 gain with that cam and switching to a fast i think im nearing the limit of the bbk i just got back from the dyno early today and made the nubers in my sig
im happy with them but theres ares for improvment i have the cam and heads to flow more but it kept peeking at 6300 on motor and 6000 on spray and droping off when i think my combo should be peeking at about 6600 to 6800 and hold its power to 7000 i like the bbk but i think thats whats holding it back
