Do all ear LS1's 97-04 have the same starter?
Old 03-30-2009, 05:36 PM
SmokinHot98's Avatar
Default Do all ear LS1's 97-04 have the same starter?
I'm selling a new reman'd that i didn't end up needing and the buy is unsure of there being different ones. Like needed shorter bolts that secure it to the block. They are all the same right? I've never heard of there being shorter or longer starter bolts. This starter was suppose to go on my 2000 T/A
TIA
Nick
EDIT: Will the starter work on the LS3 and LS7?
Old 03-30-2009, 11:30 PM
Marc 85Z28's Avatar
The original design had a long inboard bolt, and a short outboard bolt. Due to a number of block failures, the starter design has been updated - both bolts are now the same length.
Old 03-31-2009, 04:07 PM
i see, so either way all you need is another long bolt if you have the old design(i.e. original starter)?
Old 04-08-2009, 12:16 PM
need the edited question answered
Old 04-08-2009, 12:34 PM
sman's Avatar
No, the old design had a tab on the block that broke off, so they switch to a flat mounting surface.
__--- old design
____ new design
That is if I understand it correctly
Old 04-08-2009, 04:03 PM
i see, they changed around to much crap w/these starters
Thanks
if anyone else wants to confirm that would be great
