Negative battery cable and ground question
ls1 fbody, doing a v6 to v8 swap, I need to know where the negative battery cable goes, I see one part goes to the body ground by the battery but where does the other end go? Also there are several ground straps on the passenger side, where do those go?
One goes on the engine right behind the alternator. There's a hole next to the motor mount. That should be for a pretty thick ground wire. Three go on the back of the driver's side cylinder head. Mine used to be two on one bolt, one on another, but after my headswap I didn't remember and just put all three onto one bolt. I have two grounds by each head light and another one behind the fuse box.
That's all I remember... I'm not actually by my car to check for more
