Victor Jr VS Super victor
Old 04-04-2009, 10:57 AM
5.3monte's Avatar
Default Victor Jr VS Super victor
I am putting together a carb 5.3 cam is 228/231 and 590/596 lift I dont remember exactly but its close to that. Which one would work better. I will be shaving the heads down as well to raise the compression.
Old 04-04-2009, 11:29 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
The Super Victor will be over kill in my opinion
Old 04-04-2009, 11:45 AM
5.3monte's Avatar
I was kind of leaning that way, that it would be too much.
Old 04-04-2009, 12:23 PM
h8tulooze's Avatar
I am also going this route, what p/n you getting for your Vic Jr?
http://store.summitracing.com/partde...7&autoview=sku
Old 04-04-2009, 03:39 PM
KCFormula's Avatar
Super Vic is the way to go if you don't care about cutting or don't have it in a fbody.
Old 04-04-2009, 08:57 PM
SLowETz's Avatar
KCF is right..... if you're not spinning the motor high, go Super Vic(2500-6500rpm operating range). The runners are longer, the plenum is larger, as the carb pad is taller, and will be better suited for lower RPM torque.
http://store.summitracing.com/partde...5&autoview=sku
The Vic Jr. has a 3500-7500RPM operating range, and a low rpm(NA)motor will be a dog down low, as well won't make power high enough up to take advantage of the high rpm operating range.
Been there done it.
The graphs don't lie.
Quick Reply: Victor Jr VS Super victor
