lol, you've got to be kidding me...
So, this afternoon I was going back through and torquing my motor mount bolts and putting loc tite on them just for good measure and I cannot believe what happened. The first on went fine. Pulled it, put loc tite on it and re-installed it. Torqued it to 70 and then pulled the second one. I put loc tite on it re-installed it and torqued it. Well I got to about 45 (I have a digital torque wrench so I know the readout as it torques) and POP!. Snapped the ****** bolt off in the K-member. Never had that happen before. I double checked the torque specs for the car just to make sure I was right (I've done three sets of these now) and sure enough I am.
Engine mount to Engine block... 37 lb ft
Engine mount through bolts... 70 lb ft
So I didn't even make it half way. WTF. I guess I'm not really mad I'm just wondering what the hell happened lol. Anyways, my options are either drop the K member, remove the remnant of the bolt and do it over or swap to a tubular K member. I'd rather go Tubular but can I use my solid mounts with a tubular K member?
Thanks guys.
Thanks guys.
That ******* sucks man. While installing Polys in my buddy's 98 Z28 I twisted the head off one the motor mount to block bolts and proceeded to spend the next week digging the rest of the bolt outta the block. That was a good time, let me tell ya. There is barely any room to work in there, but I managed to get it out without having to pull the motor or drop the K-member. I did remove the MM pedestall and one of its bolts was pretty shitty. It was really tough to break loose, so I sprayed it with some penetrating **** and worked it loose. It ended up being all rusty so I replaced it. It's like a $4.00 bolt from GM. Anyways, thats my experience. Whatever you decide to do, good luck with yours.
