Damnit.. forgot to put intake gaskets in
Old 04-05-2009, 02:13 PM
Chase22's Avatar
Default Damnit.. forgot to put intake gaskets in
Well.. I installed my LS6 intake last weekend and for some reason I remembered that I did not put any gaskets in. The car seem to be running fine (I dd it). Although its not horrible, I dont want to have to take it off if i dont need too. How neccisary are the gaskets . I am getting a tune tommorow so I need to know.
Old 04-05-2009, 02:33 PM
thunderstruck507's Avatar
are you sure they intake didn't have gaskets already?
Old 04-05-2009, 02:45 PM
jsteele90's Avatar
if you didnt have the gaskets in im sure it would be running like *** im sure it already had the oem ones in there
Old 04-05-2009, 03:19 PM
conan's Avatar
I'm betting you have the gaskets in there, the car would not even idle let alone drive down the road with out the gaskets.
Old 04-05-2009, 10:41 PM
got-a-ls1's Avatar
yea no way at all the plastic is going to seal against the aluminum... you probably would have burnt a piston up by now by running extremely lean, if it would run at all..
did you buy it used and not touch it?
