Modifying LS1 Coolant lines for LS6 Manifold
I have been a lot of research on this topic. Since my car is a 98 model i have read that you need to grind the ribs off of the LS6 manifold. In doing so it will clear the stock LS1 coolant lines. I came up with an idea of instead buying a LS6 coolant crossover pipe I want to cut the stock lines and solder them. I would think this would mock up the same thing as the LS6 coolant crossover. and where the rear plugs would go I would just cut a small section of the LS1 lines and solder them in the back. I'm just curious if this would work to get the LS6 intake on my engine. I really don't want to spend $50 on the crossover line and i don't want to screw up the structural integrity of the LS6 intake by grinding off the ribs. They are there are a reason I would think. Does anyone think this would work?
Thanks
Thanks
i dont think the ribs do ****. i grinded them all down then wapped the coolant lines softly with a hammer so they tuck a little closer to the valley cover and BAM the intake drops right on.
I blocked off the rears by cutting the tubes off and flipping the things over so they work as block off plates once tightened
On the front I flattened it down then soldered it. No issues with it.
Just cut the coolant line and blocked of the back like others.. If I could go back and re-do it, I'd grind it down. Just like the idea of having coolant to the back. Those ribs aren't going to screw up the "structural integ."..
I'm just saying if those ribs aren't there for extra support then why are they there? Wouldn't GM just have kept using the LS1 lines for better cooling for cylinders 7 and 8. Cause then the intake would fit fine without those ribs there. Maybe they are there for the extra strength if you were going the forced induction route or nitrous?
so do you think I shouldn't worry about it cylinders 7 and 8 on a 98 LS1 w/o egr? All I will be doing with the car is driving it around town and to the strip a few times. I'll probly never road race the car. I don't have the money right now to get it tuned so will that be a problem?
Removing them is the easiest way to get that intake on. If you don't feel comfortable then spend the money and get the crossover pipe. I wouldn't personally start soldering things and trying to make your own. Not that it's all that hard but because it's a heck of a lot more work than it's worth and in th end probably has a far greater chance of issues down the road.
