Nick williams 90mm and Edelbrock Elbow???
My throttle body does not fit on to the elbow..... I was under the assumption that they would work together! Is this a problem with the elbow, or are they not supposed to fit????
I think that the edelbrock elbows can only use their TBs or any other that uses the LS2 bolt pattern. You could make an adapter plate out of 1/2 alum. stock and use screw in studs/all thread coming out of both sides. One setup for the elbow side and one setup for the TB, just make sure you don't drill and tap each side too deep. Or sell the NW TB and get an edelbroke 90mm TB.
