with ym mods, should I get a LS6 intake?
I'm looking to get some more power and i'm not ready to do a head or cam. Basically I want to get all the small stuff out of the way first. So do you think that the (mods below) will work good together with the LS6, also going to put a ported TB on while I got it apart. let me know what you think.
2000 Camaro SS red t-tops
6 speed-factory Hurst shifter
Build # 4892 now with 385HP
PERFORMANCE MODS: all SLP except exhaust, lid, cold air induction, maf, smooth bellow, larger y pipe, 160 degree thermo, fan switch, skip shift CAGS, GMMG chambered exhaust with oval tips,
APPERANCE MODS: silver gauge overlays with SS embel,black billet grille with '69 SS emblem, blacked out tail panel with silver fillins. Painted calipers silver with red brackets
TT2's 17/9.5 front and rear
http://community.webshots.com/user/slpfan
[QUOTE=
id get a nice set of LT headers before i would throw down for an intake [/QUOTE]
I agree on this point. You will see more from the headers than you will from that intake. My next mod is the LS6 intake so my opinion is biased in that I did mine that way and I do not know how much an LS6 is really worth in numbers. I did not see TB bypass in your sig. You can't get much smaller than that.
If you can pick up an LS6 intake for a decent price, its not a bad mod at all. You're going to end up replacing it eventually anyhow. Headers will definitely help you gain a bunch more horses then the intake, but its personal preference. You're not running hard enough yet for the intake to rob you of a serious amount of power, as you're heads are still stock, same with your cam. Just remember eventually it all keeps getting swapped for aftermarket as long as you keep wanting lower times
