Header flange not seating
The header flange does not completely seat with the 20ft/lbs of torque that I was told is correct, there is a little bit of fumes, I am using a factory gasket and the headers are stainless, must be a little warping of the flange I assume...what would be the best way to correct this?
i used a set of copper gaskets that were multi layered. i forget the maker of them, or if they even make them for ls engines. you could try putting a straight edge on them, maybe you could correct the problem. good luck
