powersteering resivor?
You need to pop off the metal clips holding it on and then just pull it off of the old pump. The clips have the center part bent down to keep them from coming off. Raise that part up and slide them to the side. It has an o-ring seal so make sure you don't cut the o-ring when you install it on the new pump.
