Adjusting idle with the screw
Old 04-20-2009, 11:38 AM
TooLateVTEC's Avatar
Default Adjusting idle with the screw
I need to bring my idle down about 100 RPM's, is it ok to try and use the screw in the T/B for this or do I need to have a tuner go in and do it through the computer?
It idles at around 900 and I just want to lower it like 50, maybe 100 RPM's to tame it down some.
Thanks
Old 04-20-2009, 12:12 PM
witry's Avatar
i think idle would be controlled thru the IAC motor only way to change it would be thru like hp tuners or something similar the screw is like a throttle stop with minimal adjustment
Old 04-20-2009, 03:38 PM
3800RS's Avatar
dont know. try it and see.
Old 04-20-2009, 03:39 PM
fxgs's Avatar
It idles at around 900 and I just want to lower it like 50, maybe 100 RPM's to tame it down some.Thanks
Yes, you can do it by turning the screw............then I suggest putting a couple drops of thread lock on it to keep it from vibrating out from what you set it at
Old 04-20-2009, 08:59 PM
jmm98LS1's Avatar
Idle speed is controlled only by the pcm, you cannot change it with the screw on the throttle body. All you do by changing it's position is let more/less air in at idle.....the pcm will compensate and close the iac motor to maintain it's programmed idle speed.
Old 04-20-2009, 09:02 PM
Wesmanw02's Avatar
Exactly, someone who actually knows
If you want to adjust your idle, you will need to have tuning software such as HP Tuners or LS1Edit.
Old 04-20-2009, 09:26 PM
mike13's Avatar
Do a search, I think there's a method where you set the idle and disconnect the tpis, turn they key, turn the key off and reconnect the tpis.
DaveX's Avatar
Turning the screw without tuning will cause problems. All of your airflow tables will then be off. Like stated above, it's an airflow adjustment, not an idle adjust screw. Don't do it.
Old 04-20-2009, 09:34 PM
eseibel67's Avatar
Doing this will allow more/less air in at idle but will not adjust your idle speed. PCM will raise/lower IAC counts to acheive desired idle no matter where you put the screw.
Old 04-20-2009, 09:47 PM
mike13's Avatar
I better go out and tell my engine that because it doesn't know. Raised my idle by adjusting the screw, got a code for unexpected high idle, cleared it went out did the procedure with the tps and haven't had a code or pending code. Idle stayed where I placed it.
Old 04-21-2009, 05:36 AM
eseibel67's Avatar
This is possible. Your IAC motor is at the bottom limit and cannot take away any more air when it needs to. Ideally you want some range to work with.
Old 04-21-2009, 06:33 AM
69LT1Bird's Avatar
It is probably better to tell people the right way to do it.
Old 04-21-2009, 08:01 AM
mike13's Avatar
If that was the case it would still throw a code, by unplugging it and having the pcm recognize it's not receiving a signal it throws a code. Plugging it back in causes the pcm to calibrate for the "new" sensor.
