Why does my belt keep popping off????
I removed my ac and power steering so I have a short belt but it keeps popping the belt of the pulleys when i go WOT. I have tried different belts but it keeps doing I even put a really tight one do you guys think it may be the belt tensioner???? any ideas
I was having issues with throwing mine. Changed out the belt and did it again, ended up being the tensioner so I switched it out for the Katech tensioner, no problems since.
Well I actually did take off my pulleys when I did my cam swap but I know they are in there right the only other pulley will be from the tensioner. I was going to tell you guys that I can actually push the tensioner with my hand from one end to the other with out any tools. I do have to put quite of bit of force on it but I still tink it should not be that easy. I ordered the tensioner and a new belt today will have it tomorrow will let you guys know if that helps. Thanks for all the help.
I was throwing belts and it wasn't the tensioner...I had to have a belt that was 3" shorter for a 10% underdrive pulley. There are alignment arrows on the tensioner...if they aren't lined up, then there isn't enough tension on the belt to keep it from flying off.
Also a possibility that your belt has stretched over time, causing the tensioner to be too loose...causing the belt to come off at WOT.
And the spring in the factory tensioner is prone to fatigue as well, allowing a perfectly good belt to fly away.
Thunder Racing also sells a nice tensioner similar to Katech's for what it's worth.
To tension the belt, you just use a breaker bar or decent ratchet in that square hole at 10 o'clock you see in the picture above, and then tighten the bolt on the back side...sucker stays tight for the life of the belt.
The pulley is a stock unit, so when the sealed bearing wears out you can replace it with any off-the-shelf pulley and be back in business.
Mine squeals at high rpm, need to try a tensioner but hell this one aint much more than a stock one so I think im gonna buy it, second link is the picture
https://ls1tech.com/forums/sponsor-s...ners-sale.html
http://s445.photobucket.com/albums/q...1fbodten_6.jpg
I changed the tensioner and put a new belt on for the 4th time in 3 months but I took it out for a ride and went WOT and it stayed on I will test it some more this weekend if I take it to the track and let you guys know how it went.
