what would cause a temp sensor to melt?
Old 04-25-2009, 08:59 PM
pooker's Avatar
Default what would cause a temp sensor to melt?
My 98 coolant temp sensor melted on my 98 camaro. I assumed it was the headers and replaced the gasket and it happened again. I made sure that it was not leaking any exhaust gases. Has anyone had this problem before?
Old 04-25-2009, 11:12 PM
sroach20's Avatar
never seen or heard of that problem. might check the connections in the plug, or make sure a wire isnt exposed and grounding out. i have seen bad connections cause a bulb to melt so i guess it could cause a sensor to melt.
Old 08-19-2020, 02:04 PM
April Cutler's Avatar
Default What was it?
[QUOTE=pooker;11493745]My 98 coolant temp sensor melted on my 98 camaro.
I'm having same problem, what did it turn out to be?
Old 08-19-2020, 03:23 PM
Received 3,021 Likes on 2,352 Posts
[QUOTE=April Cutler;20280757]
12-year old thread, OP hasn't been here in 9 of them.
Old 08-20-2020, 05:28 PM
showdog75's Avatar
Too much heat is the likely culprit.
The following users liked this post:
G Atsma (08-20-2020)
Quick Reply: what would cause a temp sensor to melt?
