Please help me I.D. these harness plugs
Hi guys,
putting everything back together after many months...please help.
The car has the emissions tuned out and the A/C removed.
I think this is the front o2 plug, because it has an extension... my question here is: Do you see the ground strap eye? Where does this go? On the frame? On the block?
I think this one is the rear o2 which I have tuned out, but what is the brown plug? Was that to the AIR?
I found these near the ABS under the fuse boxes...Were these also to the emissions pump that was in the nose of the car? fans? WTF?
Lastly, the one I'm holding and there's one that's hard to see right below it. Is that for the A/C and the EGR?
Thanks for any help!
1) yes, O2's. ground goes to body i believe.
2) hmm brown plug might have been to the fuel evap?, not sure
3) pretty sure those are fans
4) I think you are right, the 2 wire one was A/C, not sur eon the last one my car doesn't have EGR.
