LS1 cooling?
LS1 cooling?
I have a '93 s-10 with a '98 camaro LS1 and I'm running an '80s corvette radiator and generic over flow tank. I've been told that the GM orange coolant does not react well with air and it tends to oxidize and leave a muddy looking substance in your rad/engine. So does this mean that the radiator and coolant overflow/reservoir are sealed?
My other question is if I'm running an unsealed overflow/reservoir can regular (prestone) green coolant be used in the LS1 as opposed to the orange GM recommended?
Any input is greatly appreciated, I've been thinking about this for weeks and figured it was finally time to ask
you can use the green if you like but you CAN NOT mix the two together, rumor had it that dex-cool the orange would eat the gaskets out and cause air leaks but i dont know how many people with LS1's have had that problem, i have not. if you choose to do the green prestone you must flush the system before putting it in.
I've been using green in my LS1 swap since 2004 with zero issues.
Use the Low Silicate kind, not regular grade. Read the label and check for that wording, I use Zerex pre-mix and it specifies Low Silicate concentration.
http://www.valvoline.com/pages/produ....asp?product=8
I have a 1998 Z28 - it's over 10 years old with me as a second owner since it was 6 months old.
I have used DexCool in it since day one, but I change it frequently at a cost of less $30 (2 gals). IMO if you change it frequently you will encounter none of the problems attributed to DexCool.
We pay $6 bucks a quart for oil and change it as frequently as 2000 miles but complain if we pop the radiator cap, see sludge, and then admit we haven't changed the coolant ever. Go figure.
Maintain every system on your car and it will last a long time.
I have a 1998 Z28 - it's over 10 years old with me as a second owner when it was 6 months old.
Based both on documented evidence as well as experience, he very much *will* have the specific problem attributed to DexCool...the stuff doesn't like being exposed to ambient air as a vented coolant recovery system will do.
I think you may have missed some of his detail, but it's a swap vehicle and doesn't appear to have a sealed coolant recovery system like your '98 does.
Thanks for all the responses guys.
You are right - I missed that part. Should have read your first post closer.
With your system if it were me and since you are going to have to backflush the system of DexCool I would make the switch to Evans (2 gals around $60) and then be done with maintenance forever. It's characteristics would be perfect for your system.
http://www.dieselsite.com/index.asp?...PROD&ProdID=42
I am told the coolant at John Deere Dealers is the same as Evans and possibly cheaper.
its seems to be working just fine, if i could fit a bigger one i would definitely consider swapping
