Got my ported FAST from Vengeance!!..1 Q
Ok guys, I finally received my FAST intake and NW TB!!! Now its time to put this on and try it!!
One Q; do you think its safe to run the intake without a new tune? Will the AFR will be leaner or richer??..because I'm running nitrous and I'm wondering if its safe or not. My tune is on the safe side though, I'm more on the rich than anything on the nitrous.
About the power, I can say that the car is identical of maybe a little little bit better than it was with my LS6 and ported TB combo..is it normal because its not tuned? I thought the intake untuned would be good for a good 10-20rwhp, which is clearly not the case because I dont see any difference before/after..
Originally Posted by QuickSilver View Post
What belows did you use for it?? I need to get a silicone coupler.
You dont have an OD measurement on the TB do you(still waiting on mine)
Thanks
I used my old smooth bellow and its fine.
Thanks
https://ls1tech.com/forums/generatio...ee-inside.html
dyno results
stock heads
233 cam
ls6 with ported TB
swapped a home ported (non-separated) FAST 90/90
tuned before and after the swap
same day
same dyno
hours apart
~18hp and 12ftlbs
5-10 hp and ftlbs from 3000rpm +, never lost power
shifted my torque peak 500rpm lower
here's a recent post on a good coupler that isn't too expensive:
