MISFIRE!!! raw gas in drivers side exhaust!
Old 05-04-2009, 06:01 PM
bignutsack's Avatar
Default MISFIRE!!! raw gas in drivers side exhaust!
I just did a TREX cam, PRC dual spring, comp magnum rockers, install and my driver side 02 is going crazy. With o2 shut off i am still getting backfires and fouled plugs on the drivers side only. Can this be because my rockers are not adjusted right or a lifter went bad. My car for the first hour ran fine then all of a sudden started having these problems. ANY IDEAS!
Old 05-04-2009, 09:03 PM
RealArmyMan's Avatar
Did you tune for your new cam? Swap out injectors?
Old 05-05-2009, 06:20 PM
bignutsack's Avatar
Didn't change injectors. Tried to tune but drivers side is to up and down.
Old 05-05-2009, 08:53 PM
99Ls1fever's Avatar
Tighten The Spark Plugs....
Old 05-05-2009, 09:59 PM
What he said. Also make sure the drivers side coils are generating spark and that the plug boots are all the way snapped on.
