Throttlebody bypass question.
When you do the typical throttlebody bypass, you connect the two coolant lines that go to the throttle body. Simple.
Is there a way to delete those two lines to reduce clutter without having a negative effect on the cooling system?
alternator?
you mean throttle body?
can't really remove the lines, i don't think. what i did was run the line straight forward and along the radiator shroud. keeping it nice and tucked up against it for cleaner looks.
