Gained 18hp and 14tq from LS6 intake and ported TB
so last year i put my car on teh dyno and put down 311/325 with a lid and flowmaster catback. today i was able to dyno again, and the only thing thats changed is i put an LS6 intake and ported TB on the car. i put down 329/339. needless to say im extremely pleased with the result. does anyone else have any before and after numbers from there intake swaps???
Dyno data is never good unless its on the same dyno and same day testing. I can pick up 20hp with ZERO changes, just a different day.
If its not on the same day, but on the same dyno it can tell you trends, but it cant be exact to the HP and TQ. I'm sure you gained nicely assuming you were on the same dyno.
If its on a different dyno, you cant believe anything at all...
hwhich tv is recomended for a ls6 intake usually? wats the typical size of the bore that folks port their tb's? If i give my tb to someone, how much should they bore it to?
One was on a 80*F day with 70% humidity and the other was on a 70*F day with 38% humidity. The entire curve was screwed up, the curves were parallel to each other, one just 20 higher.
Humidity is what correction factors have a hard time with. If you keep the humidity relativity the same, the correction factor is more accurate. If you change the humidity greatly the correction factor doesn't figure in the way it changes the way the initial spark is affected.
Plus you have to factor in how its been since the dyno was calibrated.
I prefer A-B-A testing, (Baseline parts, new parts, Baseline parts) This way you can see how much testing may have screwed within the same day. A storm front can come through on a day of testing and ruin the entire day and give you a lot of bad data if you dont have a controlled air supply for the engine.
Its like any testing, there needs to be a control and a test. I'm sure everyone remembers this from science class in school.
What correction factor was used in your dyno pulls? SAE or STP (aka STD)?
I am a teller of truths , it just happens that I look into numbers more than others who stickly take them at face value.
Take it as something new learned.
I try to learn something new everyday, but try to limit myself to one new thing per day! Haha.
The power you made is legit, the two mods you did have been proven to work time and time again. Yes the dyno can read different, but who is to say it didn't low ball you. Just go to the track and see what you mph increase is. That will prove a power increase.
Edit: I forgot to add, ditch the flowmaster.
Like I said earlier....I agree, the parts you have will give you gains, but you really cant say "X" hp and "X" TQ. Sluggish is also correct, the track is where you tell the real story. Dynos are for tuning and showing differences(same day-ish), not a show of manhood...
fair enough. Im going to the track this weekend, so ill have new numbers posted this sunday. as for ditching the flow masters, i like them because they are quiet. cops here in northern VA are D**** about exhaust. im going to put a cut out on it later this year for when i go to the track.
