Sound help
Sound help
My car currently has a straight pipe version of the SLP LM1 because of the the resonator cracked. As far as sound goes, which would give me the best tone between a dynomax bullet, LM2 bullet, powerstick, or moroso spiral flow?
are sweetthunder and powerstick the same thing but pwoerstick is 3in all the way through? for some reason my exhaust sits really close to my driveshaft, the xr-1 wouldn't work where it would sit, it'd be too wide
the front part of my exhaust was welded to my y pipe to prevent any leaks, but the way the old LM1 muffler sat when i looked at it before it was removed, was about 1/4in away from the driveshaft. you could tell at somepoint the LM1 was hitting the driveshaft because the driveshaft had a ring around it where it would rub. the shotgun resonator was 4.5in in diameter, so i'd need something smaller...
