Wideband bung location on headers
Old 06-02-2009, 11:11 AM
Mart00SS's Avatar
Default Wideband bung location on headers
Does anyone have pictures of their wideband 02 sensor location. I want to put it on the driver side header collector but not sure what the orientation should be. My headers are off the car and I want to make sure that I dont put it in a spot where it will hit something when installed on the car. Thanks.
Old 06-02-2009, 12:38 PM
vsocks1's Avatar
Not sure if this helps since I have a Vette. Maybe give you an idea though!
Old 06-02-2009, 02:04 PM
TORCHD 02 TA's Avatar
see i was told to put the bung in the merge to get a more accurate reading.. You will have both exhaust gases instead of just the one.. Right now i have mine on my drivers side y pipe for when my car is on the dyno..
My wideband should be here anyday now
Old 06-02-2009, 03:08 PM
twitchtwice's Avatar
thats what i heard too, but where would you put it on an xpipe (sorry for the thread hyjack but i have the same question too.) i guess i could put it in the middle of the xpipe on the pass or drivers side?
Old 06-02-2009, 03:48 PM
Mart00SS's Avatar
I've heard some stuff about putting it on the drivers side because that tends to be the leaner bank. Usually when an engine runs lean #7 is the first to go, which happens to be on the drivers side.
Old 06-03-2009, 09:40 AM
jmm98LS1's Avatar
I have mine on the driver's side, about 10" downstream of the header collector.
Old 06-03-2009, 09:46 AM
Duffster's Avatar
passenger side ORY for ease of install for passenger doing tune while driving. . .
Old 06-03-2009, 05:26 PM
empty's Avatar
I use the driver's side for my wideband.
Old 06-03-2009, 11:01 PM
thats most likely where im going to install mine, and have the cords running through the shifter boot under the console.
Old 06-04-2009, 02:13 PM
5_02ls1's Avatar
i dont run any narrow bands so i use the drivers side o2 bung....on my buddies ss it was put about 6-8"downstream of his collector he runs a catted y and ther was no way to get 1 on the pass side .......putting it in the merge is too far away you want it as close to the engine as possible....
Quick Reply: Wideband bung location on headers
