Swivel water neck for LS1?
Anybody know if there is a vendor out there that carries a swivel water neck/thermostat housing for the LS1/6? I have a customer who is positive he saw an ad for one, but can't recall the manuf. or where he saw the ad...
http://www.hotrodlane.cc/
good timing
I was looking at Street & Peformance site the other day and they had some 10, 30, 45 Degree Neck Angle and straight
http://www.hotrodlane.cc/PRODUCTS/ls1360neck.html
good timing
Any other sources for swivel water necks since this original post? I need a 90-degree version.
Either that, or I need a fixed, "downward-pointing" water neck to replace the stock "outward-pointing" version on my LQ4.
Leads on either approach would be appreciated.
bumpage on this for the previous question, i dont want a straight one, and the one i ordered didnt work.
I need a swivel 45* for the Ls1 and im NOT paying 100 damn bucks for it. anybody got a source?
id use the straight CSR one, but for some reason, it just doesnt look like it will work.
Ok the thermostat housing is a O-ring seal right? I took mine and clocked it facing straight down and made some small aluminum clamps, and clamped it down, using the original holes on the pump. It works great and haven't had a problem with it. The clamp's are clamping on the lip of the housing.
