Fast 90 or 92?
Old 06-07-2009, 02:02 AM
TFord's Avatar
Question Fast 90 or 92?
Hey, Im currently building up my 2000 Z28. I plan on staying N/A, Im going with trick flow heads, and the 228R cam, as or right now I plan on staying with the stock displacement. whats better a 90/90 (ported?) or a 92/92 (ported?) for my application? thanks
Old 06-07-2009, 02:36 AM
LS1-NAVY's Avatar
well if u want a 90/90 u will have to find it in the classifieds cause they are not made anymore but i would have to say like a 96/96 combo from vengeance
Old 06-07-2009, 02:39 AM
lemons12's Avatar
a stock 90/90 will be plenty for your cam..
if you want room to grow (larger cam) then go with a stock 92..
a ported 90 is better than a stock 92... ported 92 is obviously better than a ported 90..
that cam wont need to breath enough for a ported 90 though IMO... max i could see is 3-4 hp.... not worth the 300 bucks to me..
Old 06-07-2009, 03:11 AM
Soul TKR's Avatar
I'm gonna get a 96/96 from vengeance with my little 224R cam
wonder what kinda gains I'll see... I plan on upgrading the cam though
Old 06-07-2009, 03:18 AM
LS1-NAVY's Avatar
man i thought i was the only one on ls1 tech right now lol
but time for me to pass out lol
ya i read some where even if the heads flow 300+cfm the fast can still barely flow that so 90/90 should be good
Old 06-07-2009, 05:40 AM
DarkJuggalo's Avatar
id go 90/90
Old 06-07-2009, 08:44 AM
SweeTbone's Avatar
90/90 just cause you can find a used one for some decent coin. Not like the 92 is THAT much overkill for your setup, cause it would work fine, but why drop that much on a new intake when a used 90 will be suffiecent.
Old 06-07-2009, 10:08 AM
MrElectric03's Avatar
Id look for a 92 used or if you have the coin the 96/96 is a nice combo.
The 92s had some better features than the 90 like threaded bosses in the throttle body bolt holes. Not a big difference but something to keep in mind.
Old 06-11-2009, 07:03 AM
TFord's Avatar
thanks, I did remember that 92's had threaded bosses...etc. I apreciate the help guys!
Old 06-11-2009, 07:10 AM
TFord's Avatar
hey I just searched vengance and all I saw was the 92, and 102mm intakes. Im sure that 102 is a bit too much for what Im doing.
Old 06-11-2009, 10:03 AM
Spd-Kilz's Avatar
I'm pretty sure that the 102 is designed for LS2 heads.
Just remember that if you buy a 92mm, you can not send it to Vengeance to have it ported.
Old 06-11-2009, 05:17 PM
SLOC5LS6's Avatar
why not?
Old 06-11-2009, 06:40 PM
SweetS10V8's Avatar
It is not, its for LS7 and L92/LS3 heads.
Old 06-11-2009, 09:30 PM
chrs1313's Avatar
has anyone seen results from the 96 setup before they recommend it over a 90 or 92...i would get the 90 because it can be had for cheaper...the opening on the 90 can be taken to 92 easily with plenty of material left...it is just marketing
Old 06-11-2009, 10:36 PM
Detoxx03's Avatar
92 buddy
Old 06-11-2009, 11:54 PM
Spd-Kilz's Avatar
Thank you! I was never sure!
Old 06-12-2009, 07:11 PM
SOMbitch's Avatar
Yep. Can't wait to see what L92's can do now with a decent IM.
