Do flowmasters really suck lots of HP
Old 06-12-2009, 11:57 AM
1badrs's Avatar
Default Do flowmasters really suck lots of HP
I want to get a new exhaust system for my car and currently have Hooker LT and cats and a Flowmaster cat back. The car dynoed out at 440 rwhp and when i opened the cut out in gained like 18 hp. I want to get away from the cut out and the cats. Was thinking of going with the Magnaflow set up but dont know if that will help or not. Like to keep it as stock looking as possible. Any input would be appreciated.
Old 06-12-2009, 12:03 PM
JScamaro's Avatar
There is a reason Flowmaster has so many bad nicknames...slowmaster...chokemaster...
You have a cutout though so if you like the sound why not keep it? If you don't like the sound then of course get rid of it.
Old 06-12-2009, 01:35 PM
00SS6spd's Avatar
If you want to make power and noise, look into Borla XR-1 mufflers. If you want power and to stay quiet, look into Magnaflow.
Old 06-12-2009, 01:45 PM
bad72c10's Avatar
Or hooker.
Old 06-12-2009, 02:29 PM
Quik Sand's Avatar
I picked up 21 hp by opening my cutout. I have mac mids through a stock catback and a chokemaster. Man that thing sux. Bout to swap in a Magnaflow
Old 06-12-2009, 02:37 PM
SMOKNSS's Avatar
I've PERSONALLY watched a car pick up 10 horses and 8 ft-lbs from simply cutting off the flowmaster and putting straight pipe on the car. Sounded like crap but gained power. As stated if you like the sound and have a cut out, you have the best of both worlds for you.
Old 06-12-2009, 02:47 PM
Haans249's Avatar
gained 30rwhp UNTUNED popping open my cutout at only 4500 rpms before having to cut the run short. Would be closer to 40-50 rwhp tuned based on how lean it was running and rpms.
Old 06-12-2009, 03:10 PM
1badrs's Avatar
Did u have the flowmasters kit?
Old 06-12-2009, 03:12 PM
Rednaxela's Avatar
flowmasters suck but when you open up the cutout it sounds and performs
great
Old 06-12-2009, 03:22 PM
1badrs's Avatar
great
I hate the sound when the cut out is open im going to get rid of it. I think i will get the Magnaflow kit and take the cats off and see what it does.
Old 06-12-2009, 03:29 PM
HAZ-Matt's Avatar
I like my SLP Dual-Dual
Old 06-12-2009, 03:39 PM
Hamrdown's Avatar
If you like the sound of the flowmaster then get a mufflex 3 1/2 or 4" single system. It uses a single pipe over the axle through a big flwmaster and a single pipe out that dumps. It's mostly hidden on a camaro set up. It's the crossflow style mufflers that kill the power.
Old 06-12-2009, 05:22 PM
ScrapinBye's Avatar
What kind of exhaust setup do u have? I have Pacesetter LT's w/ their ORY and a 3" E-cutout. At low rpm's with the cutout open it sounded like ***. Then I got the Flowmaster merge welded in my ORY and it now sounds 10X better. No bullshit. I know yall are probably sick of everyone raving about the FM merge and all the hype about it, but it is DEFINATELY worth it as I cannot stress it enough to people. Trust me, I was skeptical at first before I ordered the merge, but I'm glad I did. It really made the cutout more "enjoyable" sounding when just puttin around town. Hope this helps.
Old 06-12-2009, 06:31 PM
SOMbitch's Avatar
Originally Posted by bad72c10
Or hooker.
Yes Hooker is very quiet stock but on H/C car it is loud. I get looks at stoplights idleing and it screams WOT Magnaflow is only slightly quieter. Horsepower makes noise in these cars ... it is that simple Especially in our case where everything goes through one muffler unless you do a custom setup.
Old 06-12-2009, 07:05 PM
tripblackls1's Avatar
how about the flowmaster single chamber mufflers??
how much would it hurt if they were in true duels ?
Old 06-12-2009, 07:26 PM
00SS6spd's Avatar
If you want to make power, you just shouldn't even be considering slowmasters. Just leave it at that.
Old 06-12-2009, 07:28 PM
so you have had duel single chambers and they dropped your power a lot???
i am asking because i know there is a lot of guys that have this and wanted to know what their results were
Old 06-12-2009, 07:43 PM
HWI
HWI's Avatar
I'm running Dynatech Supermaxx LT's and Corsa cat-backs with high flow cats, it's pretty quiet at idle, but screams at WOT. It's a pricey set up, but sounds great imo.
Old 06-12-2009, 07:47 PM
00SS6spd's Avatar
No I haven't had dual single chambers specifically, although I do currently have duals with a set of no-name chambered mufflers and they're a huge restriction. But I've seen far too many cars pick up more power when they got rid of their slowmasters. Also if I'm not mistaken, when the S-197 Mustangs first came out there were GT's that were LOSING horsepower over stock when they put the slowmaster catbacks on. After seeing all of these results I wouldn't even take one of their mufflers for free.
Old 06-12-2009, 07:59 PM
are your mufflers the flowmaster knock offs that are on ebay???
Quick Reply: Do flowmasters really suck lots of HP
